SAS Pics needed
Status
Not open for further replies.
dangerous_rangerous
Hey Im new here and I am planning on doing the SAS with my 1995 ranger. My plans are to 4-link the front and rear. So my question is can you guys post up some pics of your front and rear 4-link setups? Just need some to look at and get some more ideas and angels on how im going to approach this. Thanks!
Alex
First and formost do you know what you are getting yourself into?
What are your plans for this truck? axles? wheelbase? street? trail only? tires?
Use the SEARCH function right below and to the left of where it says "Welcome dangerous_homogerous" err. rangerous
For good four link tech you would be better off looking on pirate4x4.com but dont join and make your first post like the one you made here. You will get flamed pretty bad. Use the search function heavily there also.
Search google for a four link calculator. It is a excell spread sheet to crunch your numbers in and it has a graph of how your links will work. You will be much happier with your suspension if you use a calculator than if you dont.
Are you going to UNOH?
Status
