SAS Coil Buckets
Motoranger489
For those of you who have SAS'ed 93-97 trucks, how have you dealt with the giant frame hump on the drivers side as far as coil buckets go? Pics much appreciated. Thanks
Depends on where you locate the axle. If you leave the axle in the stock location, you can probably get away with just modding the bucket. I pushed my axle forward an inch and did a little work to the frame as well as the bucket. Just a little persuasion with a hammer did the trick.
Ya I have the axle in (Radius arms mounted to frame). I moved it about an inch forward too so my bucket will be right at the biggest part of that hump. I'm gonna go at it with a hammer.
Just do a little at a time and test fit often. It doesn't take a whole lot (or as much as I thought it would).
