avincent450
- Apr 2, 2010
hey guys I just bought a sand rail with a ford 2.3L on a bus trans and it was fuel injected but it was a huge mess of wires and ran poor due to a cracked head and a broken dumy distributor drive and a lack of oil presure it smoked the motor and the wiring harnes was a mess! I have gotten a new motor that I put one of the old heads on with the angled outer ports and have a carb and intake and a duraspark distributor and have no idea how to wire the distributor and the coil! I got the distributor with a KEM aftermarket ignition box.
I want to make this as simple as possible even if it means getting a different distributor I want a simple ignition system kind of like the hei on a chevy all u have is a powered keyed wire and a tack wire. I gues what I dont understand is why I need the ignition box and is there a simpler way to do this? its just a sand rail simplicity makes for less hassel and well less wires
what my question is how do I wire this thing including the the coil (the coil is a universal one with screw on leads) and do I need a balast resistor? and if so where do I get one and what does it look like?
Any help would be greatly apreciated going to try to have this thing runing tonight!
