The manual says 45 on dry terrain...... (if I'm not mistaken, It's not really worth checking but I know it's in that range)
With a Manual Gearbox..... your a lot safer, you can gear down....... if you start breaking loose, you clutch.... I hate an auto in inclement weather!!!! the brakes will always grab harder on one side or the other. so I usually pick a gear, generally 3rd and kind of ride out the revs.... that away if you need to slow down, you release the accelerator and it slows you up gradually.......
I've been popping around here about 25-30mph with no problems.
The main thing is, when you are on dry pavement (just kick it in 2wd.....) it prevents driveline bind when turning sharp.
I just don't hard turn if it's not slick.... been cruising around in 4wd all afternoon.
the key thing is to always remember Just because your truck will go better than the cars, doesn't mean your brakes have 4wd too.... you scotch up and you might as well be a mustang hurtling toward a very abrupt stop
also.... when you get on a new road do a brake check!!! and an accelerator punch......... just to give you a feel of how slick that particular road really is..... whether they treated it heavily or not, or if its a naturally slick pavement can make a big difference in how you need to drive.
Frank
