Okay, I got you now...first you want to go by RMS ratings, not total or peak. RMS watts..All 3 have the same rating at 2 ohms stereo and 4 ohm mono (bridged)...So it comes down to whether or not you want to be able to fade your vocals FBLR or if you can deal with just LR. I have mine set up just LR, I have one 2 channel for vocals and one 2 channel for subs...if you can deal with just LR, go with one sub per amp, if you want FBLR, then series your subs to one amp...Maybe the numbers will help, if you use one amp for the subs each sub will get 37.5 watts, or if you use one amp for each sub, they will get 150 watts each, and they can only handle 100 watts each, so you can't turn your amp up all the way (keep in mind the sensitivity is not a volume knob for the amp, but can be used to limit the output of the amp)...It also depends on your upgrades down the road, are you wanting to add more subs later, like going with four 8's or four 10's, if so, it doesn't matter if you run two sub amps or one, as you will end up with the same power going to the subs...so it comes down to what you plan to do in future upgrades...
SVT
