Rusted fasteners.
"I'm just a lil irritated that Acetalyne is so expensive, it's forcing me to convert to propane for the majority of my work."
Pick up some Mapp Gas. The cylinder looks the same as the propane one, but it's yellow and the flame burns way hotter than propane: no comparison. I bought a Bernzomatic set for about $28.00 with 16 oz. cylinder included (the torch is also different than for propane so you need that). I've had an acetyline/oxygen setup for years, but find that the Mapp gas does the trick for small to medium projects.
Uhm...not really a viable option....
I'm not talking about those lil torches with the dinky 1lb cylinders, I'm talking about a full blown cutting/welding torch set, oxy-acetalyne. To fill my oxygen tank it's about $20. To fill my smaller actelyne tank, it's about $74. To run propane I have to use an adaptor, 20lb or larger propane tank (gas grille size), and buy a different tip. But it's cheaper to fill a 20Lb propane tank than my actelyne tank.
