Rust.
Strieg
U.S. Military - Active
Central California
So I have a little bit of rust on the rain rails, on both sides and I want to get it taken care of it before it gets worse but I have no idea what to do. Help?
There is stuff called rust reformer. What you do is tape off the affected area and spray it down. It WILL turn black, this is a normal condition, which turns the rust from oxidation into a black piant, but let it dry. Then once it's all dry you can wet sand it down to flat and then use factory paint to cover up the sanded area.
