Hanster
- Feb 12, 2010
It used to be when the engine was cold it would run fine and sputter when hot. But now its to the point when I start it up it falls on it's face instantly. It sputters, misses, pops. Idles all over the place. Im not sure if it is the same problem now as it was or if its because its summer and not winter anymore.
I need ideas on what to look at.
I have recently replaced these items trying to fix it-
TPS
Fuel pressure regulator
coolant sensor
cap and rotor
looked at the spark plugs
MAP sensor
02 sensor
looked at the EGR
gutted cat (thought it was clogged, it was red hot after driving 2-3mi
new air filter
had TFI checked at autozone several times
I believe the engine does run rich due to the red cat. but idk. any help would be appreciated.
TPS
coolant sensor
cap and rotor
MAP sensor
02 sensor
looked at the EGR
new air filter
