Running stock front driveshaft with Superlift: advice?
I think the pinion angle is held by the rear mount for the front diff, I wonder what it would take to shim it up a little bit to help the CV angle.
I don't remember hearing about a whole bunch of failures, I'm not exactly sure how much I would be freaked out about this... but then again I ignored a lot about anything '98 or newer for a lot of years...
The "axle" mounts hold the differential pretty flat in a RBV and the "back" differential mount bolts up to the frame. Shimming it down is possible, up is really difficult. And driveshaft 101 says you want to keep the ends parallel - or you're just trading one problem for another.
To get someone to build a custom axle with double cardan u-joint and pretty unique transfer case adapter is going to cost $$$ -- its not '98 anymore. :(
Even the option of getting an older transfer case front yoke and getting a custom drive shaft with just double cardan at transfer case isn't going to be free.​
The good news - rarely does the stock CV just fail. It give you a bunch of warning - it gets loose, noisy, etc. Having a spare axle behind the seat with a 3/8" ratchet, t-40 torx and 8mm socket in the glove box would be insurance. Usually, you can get back out in 2wd, it might not be quick but it can usually be done.
p.s The Rough Country front driveshaft at $460 is ~1/2 the price of Superlift's and I'll bet it fits..
That's good info.^
I knew I had this from when I made mine: These are the parts used by SuperLift to construct their front driveshaft.
ManufacturerPart NumberPriceQtyExtendedDescription
NeapcoN2-83-288X $ 120.89
1​
$ 120.89Flange Yoke
1310 series, 6xØ.323 Holes on 3.583BC, Ø4.094M pilot
NeapcoN16-30-102-72 $ 79.41
0.2​
$ 15.88Driveshaft Tubing
Ø2.000 X .120 Tube , 72" 14.20"
NeapcoN2-40-1701 $ 40.97
1​
$ 40.97Tube Shaft
Ø1.375x16 spline, Ø2.000 X .120 Tube
NeapcoN2-3-2001 KX $ 55.04
1​
$ 55.04Slip Yoke
1310 series, Ø1.375x16 spline
6.875 Centerline to End
NeapcoN912777 $ 177.41
1​
$ 177.41CV Head Assembly
1310 series, Ø2.000 X .120 Tube
Neapco1-0153G $ 19.72
3​
$ 59.16U-Joint - Outside Snap Rings
SPICER 1310 Series, Non-Greaseable
$ 469.35
Northern Driveline is now selling the flange yoke for $164.59; so 36% inflation says ~$600 for parts today. Building it yourself assumes you can weld/have welder. Then, you still need to get it balanced.
