SuzaMan1957
Hi Ya'll, 95' 2.3L 5SP 2WD. Before and after doing a major tune up I noticed that the engine is starving for fuel possibly. When I pulled the plugs they were a little white in appearance which indicates a lean condition. So I decided to check the fuel system. Here is what I got.
KOEO.....35-40.lbs but the pressure slowly drops.
At Idle....30.lbs with vacuum on regulator
At Idle....40.lbs without vacuum on regulator
FYI....replaced fuel filter, PVC, EGR System checks out fine, 20.in of steady vacuum off the intake. Getting 21 mpg. I'm thinking about replacing the fuel regulator. Any thoughts?
