Tader82
About a month ago i changed my plugs and wires with motorcraft plugs and autolite wires. Seemed to fix my misfire at first, but its back. In the past few weeks I have had times where it starts running like crap and the cel flashes, but not as often as before I changed the plugs. Just got back from advance auto to pull the codes. It came up with P0302- cylinder 2 misfire and P0171- lean bank 1.
Any ideas where to start are appreciated. I think I need to check for vacuum leaks and check the fuel system, but Im not sure about how to go about doing this.
The guy at the store suggested running some injector cleaner with a tank of 93 octane, said it would burn anything out of there but im skeptical.
I should also mention that I averaged 11.5 mpg on my last tank, which I just filled up yesterday. Any help greatly appreciated!
as he said he is getting a LEAN on bank 1 i have had it pop on a cam shaft poison sensor tons of time (i have put 5 cam poisoning senors in my truck i finally fixed it with a hole new synchro.) and he said that he has replaced ALL but the coil. and I'm not saying to buy the pricey stuff thats y i say to use the accel coils 80 bucks not 180 something. so i short i was not Throwing parts at it remember we r not there we can only make judgments on what he said he has checked. the Alone thing else i can think of is bad injectors
