- Jan 17, 2009
- North Eastern Ca.
My original 86 motor used to heat up on long slow runs it had a small fan and no shroud just a little safety plate on top of the radiator.Look around for a bigger fan and a shroud if its only when your going slow but you did'nt mention that.When my second motor a 4.0 lost a head gasket I could tell by bubbles coming out of the radiator cap neck.What you do is keep topping off the radiator watching the filler neck so if bubbles come out there right there where you can see them.Watch it carefully though so it dos'nt blow out and burn you.If that dos'nt work there is a test for burned gases in the radiator so you can tell.It could also be your radiator not getting good circulation I put a double thick radiator in out of a gen one explorer that made a huge difference for me now I can be plowing through snow spinning all four four tires for as long as I want and it stays on the bottom of normal.
What I would do is see if I could find a thicker radiator at the wrecking yard don't mention that it's better than the others unless you have to for price.Save the hoses sometimes the bottom one is a little different mine bolted right in.With this and a good fan with a shroud plus your thermostat if it still gets hot i'll bet you have motor problems.
