mwake83
- Dec 21, 2007
I have a 88 Ranger with a 2.9l. It has developed a rough idle over time (the idle bounces constantly from 900rpm-400rpm). It will usually idle fine when it is first started but will start having this problem as soon as the engine is revved up. I have no codes. Parts I have replaced recently with no change include: plugs, wires, cap and rotor, map sensor, 02 sensor, coolant temp sensor, fuel pump and filter (I have 35psi fuel pressure) and I have checked for vacuum leaks.
I tried replacing the idle air control valve today and it makes the problem worse, i.e. the engine just dies when coming to an idle. But when I start it again it will idle perfectly until the engine is revved again. I have tried 2 different, new IAC's and both do the exact same thing. It seems to run best with the original IAC which has 235k miles on it. Any suggestions? Thanks in advance.
