Hey guys, been having a bit of trouble with a really rough idle lately. Typically I'll start it up and it will idle a few seconds then cut out. After starting it back up it will fluctuate between running normal and sounding like it's about to cut out every few seconds or so. If I drive it around it will often cut out when slowing Down.
HOWEVER once the engine has been running a while (10 min or so) it eventually returns to normal and will stay that way the rest of the day.
I've changed the plugs and wires but nothing changed
Someone suggested I may have a vacuum leak but I dont think that would make sense if my truck runs fine after warming up
Any thoughts or suggestions? Thanks
Fuel injected engines use an electronic "choke", the computer controls this.
When engine is cold computer will run injectors rich, raise the idle and advance the timing.
So to tell if computer is doing it's part, your idle should go up to 1,500rpm when first started.
Then drop to 1,000rpm after a few seconds.
Then it will slowly drop rpms down to 750rpm(normal warm engine idle) as engine warms up.
If this isn't happening then there could be a few things that could cause this.
The IAC(idle air control) valve is how the computer sets the idle, it is located on the upper intake.
These get dirty and computer can't set idle correctly, they can be removed and clean.
If this valve is stuck or dirty then cold idle would be iffy, but as engine warmed up it would start to idle fine.
The ECT(engine coolant temp) sensor is what tells the computer the engine is cold or warm, this is a TWO wire sensor located near the thermostat housing, this is only used by the computer.
The dash board temp gauge uses a ONE wire sender, usually located near the ECT sensor.
The ECT sensors rarely fail, not never fail but rarely.
These are simple resistance sensors, so can be tested with OHM meter.
IAT(intake air temp) sensor, this tells the computer the temperature of the air coming in to the engine, colder air is denser so requires more fuel in the mix, on the '94 this sensor is on the upper intake, in later years it was combined with the MAF sensor(6 wires).
I would expect a problem with the IAT sensor to show up even after engine was warm.
MAF(mass air flow) sensors need to be cleaned every few years, it is easy to do and will improve mileage and performance.
While I don't think this would cause cold engine issue, it could, and is simple to clean.
Click here:
http://www.therangerstation.com/tech_library/CleanMAF.shtml
