2.5L ('98-'01) Rough idle, ignition issue?
Micahfriesen
Salem IN
I'm planning on trying new spark wires. Oreilly's has multiple different brands, is this engine picky about what brand of spark wires it uses?
Go with motorcrafts
They're not too picky, I would go with Motorcraft or Autolite for spark plugs though.
If it hesitates and such I would pick up a can of MAF cleaner too and clean the mass airflow sensor...
I run iridium NGKs and have no issues.
Brands for wires is kind of a crapshoot, Motorcraft wires are OEM and are made well, but are usually a bit more expensive.
I would avoid the cheapest of the cheap wires since they typically have pretty high resistance, like Standard Motor products.
NGK makes a solid wire for less than OEM.
I don't know if hesitation is the right way to describe it, because it doesn't really. Anyways I bought spark plugs today, I will replace them and see where we are at. Spark wires will be next if that doesn't fix it.
Change out the 4 passenger side plugs first, it'll run on 4 of 8 spark plugs, the back two plugs on the drivers side pretty much require a 5 year old to do it or removal of the upper intake
Well it took my 17yr old hands 2.5hr to do all 8 plugs, without removing the upper intake.
Sweet! I looked at mine and just said screw it and pulled the upper intake, proceeded to break the PCV valve and missed a vacuum line and I think took longer than that with all of that :)
I hope it helps, on my '97 at like 175k when I did the plugs I think the drivers side were original, was getting a #2 misfire code where the plug wire had come off the coil pack and melted through the insulation on the coil... conveniently I'd just bought a coil for my V8 Explorer so I put it on there instead (the Explorer had a different problem turns out)
So one of the driver side spark boots broke when I pulled it out, and I just slipped it back together. I can hear it arcing though, so I just went ahead and ordered spark wires. I also ordered coils, because when I unplug the driver side coil, the passenger side is missing. So we shall see how this improves things.
So what youre saying is the other 4 are worthless?
No, they helped it to get to 170k without changing them :)
