Rollover vent line problem
Thomas hanson
Orlando
Hi I’m having a problem with the vent line on top of gas tank on a 2008 ranger . Tge line seems to long and is bending the nipple . Can I replace the line with a new quick connect or clamp . Thank you
That line can be replaced.
The vent valve will also turn in its grommet to help prevent a kink in the new line.
Thank you. It didn’t appear to move. I read that composite f150 tanks-it’s not removable and didn’t want to force it . I was able to cut and shorten the loose enough to get it into a normal position
