Rollover cab damage
Arronpotts
Stockton ca
Long story short I hit a tree, the cab top wrinkled really bad straightened it enough to get a new windscreen in but the cab is f@&$?d is there a cheaper way to replace or fix the scars? Anything would help thanks in advance
I usually just wave the magic wand...
but seriously... depending on how bad... probably just replace the cab. Let's see pictures... maybe someone will have an idea.
Welcome to TRS...
Welcome to TRS...
Thanks, long time consultant but needed some help. Sorry I don’t have a pic of just damage maybe when the sun come up
Id pry just buy a cab. Being a white XL it should be easy to match up even
If you get a different cab be sure to get one with a title, you might check around, in CA they may not like the cab VIN not matching the frame VIN too... plus emissions stuff if you change model years.
Here is an inside photo of the damage any comments?
