rickcdewitt
c) Around 85/86, started using roller lifters on some aplications.
i wondered if anyone could help narrow this down for me in an 86 E-150
IIRC, Truck blocks were roller-ready, but never came with roller cams from the factory.
thanks badd,wasn't sure if you'd want to post?Wrong info...........................The pickups and van 5.0's got roller cams in 1992 with the same small roller the Vic/Town car/Marquis 5.0 used. Then in 1994 they got a much improved roller (this one was called the F4TE cam) that's just a step below the HO cam on the intake side. This cam was later used in the 96-2001 Explorer/Mountaineer 5.0. Prior to 1992, the pickup/van 5.0 had a roller block but with a flat tappet cam starting in 1986.
so your sayin' 86 is roller ready,but to 93 it was flat tappet or a reduced base circle/ crappy roller lifter(or just refering to low lift)?
