roll bar
probably need to take a couple inches outta the middle since u got a stepside. but hey if u got a welder and a grinder with cutting wheel you can do alot
u will need to do something about the rear tubes too. since those are meant to go on the wheel wells. and stepsides dont have wheel wells.
or its meant to go on the bed sides(rails)
snowman's right. Its gonna be hard to find a bar that will fit a step side. with my bar, I had to cut it to fit. you can always ask the seller the dimensions, but if what RSH is true, then you should keep looking. good luck :icon_thumby:
sure as hell looks like it in ur pic. everyone assumed it was your truck. even if its not a stepside you will still probably need to cut it up
if its not too far you could just ask to try it out before you buy it. or call and ask for some dimensions.
ya snoman thats my friends ranger mine isnt done yet thats why thats my pic
o i see. well it still loks like at the least you'de need to swap the rear mounting plates to fit the wheel well better and maybe take an inch or 2 out of the center just for ease of gettin it in and out
