rod knock ? help please
you should consider yourself lucky...a guy can never have too many projects.
idk wicked , sometimes having too many projects means that you do not pay enough attention to each of them
Oh, believe me, it is possible to have too many projects!!!
Too many may be more than you have imagined though.
Also, when you turn a crank it is undersized bearings that you need(not oversized) the size depends on how much has to be turned out to be made true.
naaa, just gotta pace yourself :icon_thumby:
yea , that is why the cutlass and the 72 have been shelved for now and the ranger is my top priority seconded by the sploder , hopefully the ranger will be done at thanksgiving , and the sploder will be gettin some new body panels in january
the truck on the trailer after i got it home from alfred , all the pics of the tear out are on the home comp
is it just me...or does that front tire look way bigger than the rear?
it does look bigger , but that is just a combination of the camera angle and the fact that my rim is solid black with brake dust , and while on the topic what do you think are the best brakes , that produce the least amount of dust
couldnt tell you as ive only owned one vehicle with an automatic and i didnt own it long enough to change the brakes.
being that i use engine braking 90% of the time, i run the cheapest, softest, organic pads i can find. they cause the least wear on rotors meaning i can avoid replacing my $90 rotor by just replacing $20 pads instead :icon_thumby:
yea , see i never had this problem with my 96 , it was a manual , so i rarely ever used the brakes , in fact i owned the truck and never replaced the pads , and i put new pads on the 2000 , they are ceramic , and now i have more brake dust on the rims than i did with the cheap pads on it
ouch. makes me wince whenever people use that word in relation to brakes.
the only reason i bought these pads is the backing plate , when i use the regular pads they have a steel backing plate and new yorks choice of road deicing and friction material does not play well with those backing plates
IIRC, my cheapo napa pad material is riveted on...but i may be wrong...its been a while.
yep...them'r brake pads.
never heard of them, so i couldnt tell ya. they sound ok....:dunno:
idk either , i figure i could give them a try , i am already doing so much with my truck , the engine , and now i am replacing one of the leaf packs since i broke a leaf about 2 or 3 weeks ago , i might as well do pads too , and i have to power wash the frame this weekend since the engine is out , still aint clean from muddin a month and a half ago , so i am also gonna clean the rims so they aren't black
