RangahDanga
What are the chances that I can swap from 3.73 gears to 4.10 gears in my 8.8 and not have to do all the crazy measurements? I've got a good axle that doesn't howl now, and I'm replacing the gears with OEM Ford Racing gears, so assuming i keep the shims in the correct position i should be able to swap one for one and forego the crazy measuring? i'd be doing bearings while i was in there, and likely replacing the clutch pack also. I can, but would rather not, bring it to an axle shop.
