Rim size?
CrustyRanger
Tucson
2.9 V6
So I just got a 90 Ranger xlt. I'm getting a 4 inch lift for it, and a 3 inch body lift. Was wondering if anyone would know if 15x8 inch rims with 3.25 back spacing would fit, without cutting the fenders? Gonna run 31x10.5x15 tires. I put the rim without the tire on the front of the truck, and the rim sticks out about 3 inches past the fender.
Well with the 3" BL alone you should be able to fit 31's with ease. The extra 4" lift would look better with 33's. If anything the 31's look too small on my 84 with the 3" lift.
But you would be better off with some 15x8 rims with about 4" of backspacing. They won't stick out really far just a little over an inch.
Ok, that sounds good. I will go with the 33's. The reason I ask about the 3.35 back spacing, is because I got a set of rims for free, and I would like to use them.
