- Sep 21, 2008
- toney,al
- Manual
I like this idea. Slamming on the brakes, basically locking them up usually does it as well.
Other than that, a BFG hammer does the trick, but like he said, be careful. Hitting the tire can bounce it back and hit you...![]()
you can pop the rear dif cover off an pull the c clip then pull the whole shaft an drum off as one.
Wow, everybody's already listed all my ideas. I can't wait to hear the final solution to this one.
Thats a good idea but seems like It could possibly end up making just to much work for this.. Does the hub uncrew/pop out or how would you access the hub like get it out. Becuase the rims severly stuck to the hub and if i could get that off then id just bang it apart on a bench.
Could you maybe put a jack behind the tire and against the fram and push it right off? a cylindrical jack like the one they give you under the seat for the emergency kit..
