master hec0
so i noticed that my marker light on the right side under my headlight was not working it would still signal but just not light up as a marker so i figured that one of the 2 filliments was burnt out. went to napa and got a new bulb.
now my marker works but my right signal light will not light up. none of the right signal lights light up. what should i check 1st? the fuses should be fine since the other side the lights work. also i went and got another bulb from ford to see if maybe i had gotten a dud. same issue
