rraff19
- Jan 24, 2014
- Automatic
Need some help here.. 1989 Ford Ranger, 2.3 - having an issue with the idle and it's getting worse, also bad shift points, bad acceleration. Had these problems for a year and then problems disappeared after installing new ignition module, new cam shaft sensor, new ignition switch due to truck died and would not restart. after replacing these parts truck started and ran excellent for 3 months, all problems are back and are worse. Tonight replaced battery and alternator due to battery light started coming on. Idle jumps from 300 to 1,500 rpms and is almost stalling after it slams from 1,500 to 300rmp, this happens at idle and idle jumping all over when driving. Just bought new idle air and ignition module to recheck and made no difference, so I reinstalled 4 month old parts. Checked vacuum lines and replaced all lines coming out of vacuum module. Any help would be appreciates. Thanks
