Reverse Lights not working
ussnipe23
Virginia
I need help. I have a 2000 Ford Ranger 2WD with Automatic Transmission. I have no reverse lights. I have checked the fuse and have power at the fuse. however no power at the rear of the vehicle. I have checked wiring diagram and wiring running back to the rear and have found nothing out of the ordinary. I read something online that the overdrive wire on the shift knob might be shorted on the column (fixed that issue) still no power. Checked the switch that is on the transmission and jumped the switch and had lights. Replaced the switch with new one and the lights still don't work. I'm at a loss for words because if I jump that switch I have lights but once I connect it goes away. I need help.
If jumping the switch at the transmission makes the lights work, then that switch is the problem. Either bad switch (could have gotten a bad one from parts store) or switch is out of adjustment or whatever triggers the switch in the transmission is broken, missing, worn, etc.
That's what I'm trying to figure out. I haven't found anything that says there is something inside the trans that tells it that it's going in reverse. I will have to ohm the switch to see if the new one is bad. Adjustment is good because if it's not right the truck will not start if out of Adjustment. Truck starts. Any other ideas.
Keep in mind that the neutral safety switch (for starting) is not the same as the reverse switch. Of course, if you're in reverse, you're not in neutral.
I know it's going into reverse. The truck wants to go backwards. The switch that goes on the transmission controls several different things. Is there something inside the trans that relays to the switch? Because as far as putting new switch on it just goes on a rod that hooks to an actuator that goes to the shifter.
I think Eric may be describing a manual transmission. There is no separate back up lamp switch on an automatic transmission.
I don't have schematics for a 2000... but the backup lamp switch is part of the NSS/Range switch on an automatic transmission.
If you can jump that switch and backup lamps work... it indicates the switch is bad or improperly adjusted.
You could disconnect the range switch connector and check the switch for continuity when the transmission is placed in reverse.
Very true. I replaced that and installed new one how it showed. But will check that when I get home. Thank you. Will let you know what I find.
Cut the ground wires for the bulbs at the back of the truck. Clean a spot on the frame and bolt the wire from the bulb to the frame. I have seen this fix so many taillights and reverse lights over the years on older vehicles.
Ok. So there might be a bad ground. I can check that. Thank you.
If the tail and stop lights... hell even the backup lights when jumped work... the chance of it being a bad ground is pretty slim. Those lights share a single ground.
But anything is possible I suppose.
All lights work except the reverse lights. Only problem I'm having. That's why I'm stumped.
Doesn't really sound like the typical dirty/loose ground issue.
I know. And the NSS/Range switch is not out of alignment. It can only go on one way and if done wrong the truck won't start. I really don't know what else to do. It is raining now so I can't go check continuity of the switch.
So I still have no reverse lights. Have tried it all now. I really don't know what I'm missing here.
hey, i am wondering if you have found out your issue, i have the exact same issue.
My Reverse lights just stopped working one day, i inspected all fuses and they were good, especially Fuse 20, i have already replaced the DTR if that was the issue but it did not solve it and it Starts like it should in Park and Neutral and no other gears ?.
i have an 2008 ford Ranger Fx4 4L V6.
Let me Further Explain my Issue ......
my ABS & Brake light would turn on randomly and i noticed that fuse #20 was blowing so i replaced it and it would randomly blow again, it doesn't do it all the time and the lights would go away once i replaced the fuse but would blow the fuse random again.
since this is the same fuse for my Turn Signals, i put in a Auto Resetting Fuse that Resets after being popped until i was able to track down the Issue since i was running low on fuses.
after i did this i didn't see those lights on my dash again, i assume it wasn't even Popping the fuse since i couldn't see the lights for 30 seconds at least, so i assume Problem Solved ?
Well, One Day my Backup camera wouldn't turn and, so i checked the fuse OFC it was still OK but my Reverses light Now do not work Anymore.
Before this i had an assumption my ABS Sensors or Module was going out.
so i First Tried to Replace the DTRS Since the ABS is Still Working with that Fuse, Replaced it and Nothing.
The Only Other Components i think that might be causing it are the Transmission OSS, Rear ABS Wheel Speed Sensor, ABS Module, Shift Interlock Solenoid (Still Works), Transmission column OD Switch (Still Works), Speed Control Module or Cruise control module (Self Diag Confirmed it Works) and The Turn Signal / Flasher (Still Works).
I Plan on Replacing the transmission OSS, Rear ABS Wheel Speed Sensor and the Shift Interlock Next.
After that, i am Stumped.
