Replacing the Pivot bushing.
Madracingalley
Gansevoort, NY
I just got my new I-Beam. and with a bonus it came with the radius arm and the spring!
So my questions are....
How do I replace the pivot bushing?
Is it possible?
in my experience its easiest to remove the beam from the truck completely and use a vice or a hydraulic press to remove and then install the bushing. its hard to happer or pry out because it has a steel sleeve around it (unless its a polyurethane bushing, then getting the original one out is the only hard part). you might be able to use a ball joint press to change it if you have cups that are the proper size.
