four100d
- Jul 24, 2010
- Ohio
- 4.0 V6
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 31/10.50-15
I thought the rear main seal was leaking, but turns out it was the lower intake. Also the head gaskets needed replacing. I decided to get a set of rebuilt heads and bought some new rocker arms, pushrods and gasket set.
Anyway, my questions:
Do you have to paint the heads? If so, how do you paint them in cold temps? Our garage is not heated and its not going to get to 50 degrees for a while and I want to get it back together.
What is the best way to clean the head gasket surfaces on the engine block? I started using a scraper and wire brush wheel on my drill, but I stopped and figured I better make sure I don't mess anything up. Also do you have to get every last bit of discolored stuff of the surface (like down to shiny metal)?
What if some of the small particles get down in the holes where the head goes? Should I flush the coolant system when I'm finished putting it back together, before I start it up?
Do I need to pour oil on the new rocker arms before I put the valve covers back on?
Any other tips anyone can offer would be great...
Thanks.
Thanks.
