Replacing Fuel Injectors 94 2.3
Moreflying
California
Is it possible to replace the fuel injectors on a 1994 2.3L without pulling the top half of the intake manifold/throttle body off? It looks pretty tight in there. Also, is there anything I need to get parts wise other than the injectors and o-rings? Thanks!
So when you did your injectors, you pulled the top half of the intake/throttle body? Is there anything I need to be aware of, and were there any snaggs you ran into while pulling the intake? Also...again is there anything I need to replace with injectors except o-rings? Thanks.
