I'm thinking the '99 too...since most if not all the time, IFS means 98+ and TTB means 97 and down. You really don't see people calling TTB 'IFS'. If that makes sense. lol.
Since you know about the hub BS on the PVH, it's pretty smooth sailing. Remove hubs to expose CV shaft ends. Unbolt upper shock mount, upper ball joint, sway bar end links(like they're still there anyway lol), and possibly the tierod end from the knuckle. This will allow you to tilt the knuckle outward to slide out the CV shaft from the knuckle. Yank out the CV shafts from the axle. Usually a yank is all that's needed, sometimes you'll need some pursuasion via screwdriver or prybar between the housing and the fat part of the CV..just be careful of the seal. Then you've got 3 bolts(might be 4, been a year or so for me) then the diff drops right out.
I know I've removed it without fully removing the CV's, but it's been so long, that I'm totally unsure of how I did it. lol.
