john5482
- Sep 20, 2007
- Automatic
When I had been working on my A4LD transmission, I broke a section of the shift cable. Since the hard plastic used becomes brittle with age, I have decided to replace the column shifter with a floor shifter. Does any one know if the B&M Light Truck Mega shifter will work with a A4LD transmission? B&M calls out using an AOD, C4, C6 transmissions, these use 6 detentes: 1,2,D,N,R,P which are standard for most. The A4LD uses 7 detentes: 1,2,3,D,N,R,P. I'm prepared to modify the shift bracket, carpet, etc. My concern is if the ranges will work or not for this shifter. This shifter, it's the best one I've seen for light trucks. If it can't be used, what would be the best choice for automatic floor shifters used with A4LD transmissions in a 1989 Ranger super cab 2.9L?
