Replacing 4x4CM..... part numbers and compatibility?
Dan2002
Hey All,
Just discovered my 4 wheel drive is out on my 2002 Ranger. The info here has been great and it looks to be the 4x4CM. My question is the original one is a 1L54-7H417-AD, but the Rockauto website (and a couple of others) show a motocraft TM101 and reference 1L54-7H417-AC. Any issue with going with what looks like a slightly earlier version?
TIA.... Dan
No issue, thats fine to use
2001-2005 modules were the same, yes revision AE was the last one
2006 - 2011 are different
Thanks Ron, much appreciated. I'll get this ordered and be ready for the next snow!
i've been having some of the same issue. disconnected the negative battery terminal for a few minutes re-attached
and 4x4 works. this is intermittent...
1997 Ranger 4x4 control is different, it used the GEM Module as the 4x4 controller with a dual relay box behind GEM for shift motor control
The 4x4CM was use in 2001-2011 Rangers
It's alive!! Ordered my 4x4CM from Rock Auto on Thursday night, was supposed to arrive Tuesday but it got here today before lunch. A pleasant surprise, the box indicated it was an older rev of the 4x4CM ending in AC, but when I opened it the replacement was an AE - the last revision. Plugged it in, got 4x4 Hi and 4x4 Lo. Success! Total cost was right at $170 with shipping and tax. Thanks to those who posted and replied on earlier threads, you saved me a bunch of $.... and considering my water heater died today it's a big help.
Dan
