atomicjoe23
- Oct 3, 2008
- Automatic
Just wanna do a quick double check before I pull the trigger on purchasing a replacement transmission. . .
I have a '99 4WD 4.0L OHV with the 5-spd. manual. . .I lost 5th gear on it; I have found a pretty good deal on a replacement 5-spd. manual out of a 2001 4WD 3.0L. . .I know the 1st and 2nd gear ratios are a little different, but other than this is a compatible swap correct?
Thanks for the help!!!
