- Nov 16, 2008
- Age
- 39
- Honduras
- My credo
- Fortune Favors the Brave
ok so the 2.5 was running like crap again.
i took it to the mechanic, since the CEL was on.
scanned it and gave 3 codes: one for the IAC and 2 for the water temp sensors.
since the IAC got cleaned like a month ago i replaced it, along with the 2 water temp sensors.
today i tested the truck, started it cold, idles like new, until 2 minutes, the CEL went on again, scanned it and the same water temp code shows up.
cleaned the codes, and CEL went on again, same code: water temp sensor 1 on bank 1
we cleaned it 4 times and went on again. even disconnecting the battery for 10 minutes, once the engine is running it comes on.
what else could be wrong here?
is there a chance that the sensors are misplaced?
or is there something not working, so they wont work too?
