caliskier
- Dec 31, 2007
I did all four brakes on my 94 B3000 2X4, replaced the calipers in the front as well. Blead the brake system and took it out for a test. Here is what I noticed:
1. Peddle presses down with more resistance as you press further. Thought this was ok, was not sure.
2. When I apply normal brakeing pressure the vehicle seems to act fine without any skidding, Harder stop, (not pannic) the left front wheel locks up, others don't. What would cause this?
3. How can I tell if the drum brakes are working correctly? Thought this might be the cause of "2". The car does stop very well in reverse hard or soft with no skidding. Parking brake seems to work fine.
Thanks for your help
