R anger
Took heads off to find one was cracked in between two of the coolant ports. I have new heads ready to be put on and I don't want this lifter to tick when I'm all done. It seems to be the front passenger side lifter that doesn't get enough oil. It looks like this end of the rocker arm shaft was plugged a bit . Maybe this lifter is now plugged? Is there a way to clean out the lifter/rocker shaft, or can I replace all the lifters without replacing the cam? Truck has 210 000 km.
