themaxx69
Rebuilding my tranny, noticed 1st and 2nd gears have some wear and 3rd was seized to shaft and the part with all the "small teeth" broke off, and main shaft is worn in a few spots.
So, I found the main shaft, then I noticed the 4.0 comes with higher gears in 1st, 2nd & 3rd than the other engines with the same tranny. So, couldn't I put 1st 2nd & 3rd from a 3.0 on my shaft?
And, would I also need the counter cluster gear? Is it that easy
Seems a lot easier and cheaper than changing the axle from 3.73 to 4.10...for now.
4.0L 3.40 / 2.05 / 1.31 / 1.00 / 0.79
3.0L 3.72 / 2.20 / 1.50 / 1.00 / 0.79
