Forcus
Hi guys,
I am removing my smog pump for "off road use only". I originally thought I could use a 5.0 Mustang smog pump eliminator but it 1) uses a serpentine belt pulley and 2) uses a pulley that presses on a shaft and is not secured with 3 bolts like the original.
I believe I can run a shorter belt, but wasn't sure if there were any other options. I have PS, Alt, A/C, and of course water pump and crank pulleys.
Thanks in advance.
Thanks in advance.
