Removing frame rivets?
Quasi242
January 2010 OTOTM Winner
OTOTM Winner
Tucson, Arizona
For those of you who have flipped your shackle hangers, what is the secret to removing the rivets? I have spent a few hours grinding the heads off one side. I thought that with the head removed, I would be able to drive them out with a 5# sledge. Unfortunately they will not budge. I would prefer to not drill them out as I want to keep the original frame hole as close to stock as possible. Any help would be appreciated.
cut an X in the head and use a chizzel (sp?) to hit the cut up pieces off. You really should bore those holes out to fit a 1/2 in bolt though.
x2..i cut an x then use an air hammer
ive done the x trick with the air hammer and chisel and it works, but my favorite is to torch the head off then use a punch in the air hammer and drive them out that way. ive got a steadier hand with the torch than most though.
Thanks, for the input. I have already removed the heads with a grinder. It sounds like I need to get my hands on an air hammer with a punch.
I usually grind the rivet head flush. Takes a minute or two.
I have never came across any rivets where a good punch and a good hammer wouldn't do the job.
If its in a hard to reach spot an air hammer will be your best friend like others have said. But I have gotten away with out one.
I just ground mine off a few days ago too. Make sure you have them ground completely down (you can see the circle in the frame). Then make good solid hits. The first one took me 5 minutes, the last one took me 5 hits. For my own hammering I find holding the punch with a vice grip allows me to focus on hitting instead of being hit (meaning I get a better wallop on it).
I second that. Really sucks to smack yourself.
I paid a guy to do it for me, $50 and they were done and bolts were in...:yahoo:
thats soo cheap...no way in hell would I do that for $50
^^X2
Grinding the rivet heads down took me approximately 15-20 min. per head!
