I'm having trouble trying to visualize how to remove the pumpkin. I just got my set of gears and my locker will arrive on Monday so I want to remove it and start setting it up.
My d35 is mounted on the axle beam but its not mounted on a coil spring. Same with the passenger side. My plan was to remove the passenger size pivot bolt and slide the axle shaft out of the other shaft. But, what about the other side? I know I remove the bolts holding the pumkin in but is the drivers side axle slide into the pumkin? (I looked at a d35 exploded view and it said it has a snap ring)
Thanks!
Thanks!
