- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Short story: Anyone got tips for removing sprayed in bed liner from my truck? I'm thinking heat gun and patience.
Long story:
Had a small lawn and garden battery in the bed of the truck and did not realize that it had turned over. Battery acid ran out all over the bed liner and caused it to start lifting.
I know that something like baking soda is best for neutralizing the acid, but I doesn't have any at the moment. I removed the battery and everything else that was in the bed and flushed it out first with water, then Dawn dish soap and water, and finally flushed with water again. If nothing else hopefully that at least diluted the remaining acid.
I suspect that some acid has gotten under the liner. I want to start removing the liner and properly neutralize the acid but I don't really know how to remove the liner that hasn't started lifting. I'm thinking a heat gun and pair of gloves will do the job, heat sure makes the edges turn loose during the summer.
FYI the liner is a Reflex brand spray in that hasn't aged well. Been planning to remove the liner and have it resprayed for a few years, this just gave me some final motivation. Once I start I'll be removing all of it, but this acid area is the primary objective. Once finished I'll either have it resprayed professionally or a DIY like Upol Raptor Liner.
Long story:
