removing 2.3 clutch cable?
There's a large "quick release just outside of the bellhousing. small plastic washer that needs to be 'pushed in' to release the spring.
The part that is actually attached to the slave, inside the bellhousing, has a mall pin that needs to be driven out. This cannot be done while the bellhousing is attatched to the motor. (hence, the quick release)
right on thank you!
i wasnt sure if that pin was supposed to come out or not. ive got my motor out but left the trans in because i couldnt figure out how to detach it. im a little slowww :icon_confused:
