compleckz
i've been trying to track down my misfiring problem, my current step was checking the fuel injectors, i was going to check out the #4, and either clean it or swap it with another, to see if the problem moved with the injector..
well all went well till the injectors came out, they came out pretty easy but something was missing.
the o-ring was still in the hole, and i was able to carefully fish it out, but the plastic end piece is MIA. i've never dug deep into this engine before, i don't know anything about it, so has this plastic piece fallen all the way into the cylinder?
also what is this thing, and why is it so ass-dirty?
the o-ring gasket for that thing was broken:
and it goes into the upper intake here:
it seems like with having to put a new gasket under the fuel rail, and all the stuff that needs to come off (and possibly more now) it might make sense to do a bit of an overhaul on the top end.. i have an oil leak from somewhere, maybe valve covers, and im getting this misfiring problem, which could be a valve..
what does everyone think about.. everything?
