twonole
The past few months the a/c in my truck has been mediocre at best in the Florida heat. Today I went to the local parts store and bought a $30 r134a refill kit, unfortunately they all had stop leak and no other options were available :/. So anyway, I filled it up in the drive way today while it was about 91* outside so I put the whole can in til the gauge read just under 40psi with the compressor on, on the low pressure side. Now the pump was hesitant to turn on and would run for about 10 minutes straight and turn off and not come back on, so I unhooked the ground and let the computer reset. So now the a/c will cycle normally and blow ice cold but for the first 5-10 seconds the compressor is on it makes almost a groaning noise, I wonder if it could be the clutch or if I need to borrow my grandfather's manifold set and put in oil for the compressor. I'm also worried the the stop-leak may be causing it. Any help is well appreciated. I'll get a video of it up tomorrow after I get home from school.
