bigdan002001
I am in the process of tearing everything apart...buffing/sanding beams and everything and painting everything on the front end of my truck with the D35. I am now reassembling things and put my new radius arm bushings on the passengers side first and bolt it to beam, then put it thru the bracket and started the nut...put the other end of the beam up and anchored it thur the beam support bracket. Now that I have simply snugged up the radius arm nut, the beam is very stiff and I cannot shove it up or down very much at all. There is no way I will be able to reinstall the coil springs let alone my new taller leveling springs. I bought the hard plastic high temp bushings from napa for the radius arm and was wondering if this was a mistake and not allowing me to have any movement on my axle beam to let it flex down enough to slide in the coil? The beam currently is only about 1" below the bumpstop...so it is very high....should I swap out the new bushings for some new rubber ones instead or just loosen up the radius arm to allow assembly? Will these bushings pop and make a lot of noise too? If so, I might just go ahead and buy some new rubber ones...
Thanks,
BigDan
Thanks,
BigDan
