Assuming clean fuel injectors
Lets start with that vacuum leak thing
Warm up engine to operating temp, temp gauge should be above 1/3 but below 1/2
If not then you have a bad or the wrong thermostat, 192 or 195degF is correct one.
180degF is bad.
Now at operating temp and idling at 600-700rpm
Unplug the IAC Valve wires
Idle RPMs should drop to 500 or engine may stall, either is good it means no vacuum leaks.
If idle stays above 700 then you have a leak......OR, someone has been playing with the Anti-Dieseling screw on throttle linkage, it is NOT an idle screw, should be adjusted with IAC Valve unplugged and engine warmed up so idle is 500 or less.
So RPMs stay high and Anti-Dieseling screw isn't the issue, start by unplugging each intake manifold vacuum line and plugging that port with your finger, if idle drops you found the leak point.
If not found then next test will be after engine cools off over night or 6 hours.
When engine is cold loosen and remove fan belt from crank pulley
Have a can of starter fluid(ether) handy.
Start engine, it can run fine with no water pump for 2 minutes, Battery Light will stay on
With no fan blowing air over engine finding a leak will be easier
Spray ether around lower intake while listening for RPM change, also upper intake and the air tube from MAF to intake
Spark plug gap, 0.054 is for stock engine, you are pulling in more air and so more fuel, may want to bump that up to 0.059
Wider gap gives better low RPM performance but less coil recovery time above 4,000rpm, so gap is relative to drivers needs, the 0.054 is average use stock
Bigger cams can cause engine to lope, and with MAF sensors this can cause issues but as manufacturer said it is not likely, and a lope is different than rough running.
Is idle better cold than warm?
