mhavoc
- Sep 26, 2010
Hi experts...
I have had my 1986 Ranger 2.9 for about 10 years now and finally bit the bullet to have the entire engine rebuilt rather than trying to hack it together. I used Kunz's excellent info as a roadmap as I bring this baby back to it's full glory. Anyway, now to the problem I am having.
In a nutshell, starts right up... runs great, actually purrs, you can hear it's pleasure after being completely rebuilt. Revs nice, doesn't seem to miss. UNTIL.. it hits operating temp (the mystical ~145 seconds) and the ECM switches to closed loop, then the engine starts to sputter and after about 3 seconds it stalls. From the exhaust there is massive gas odor so it seems like it is flooding itself out (more later on this). It will start right back up if I floor the gas pedal, but if it is already at temp, then after exactly 4 seconds, the missing followed by a stall happens again.
On the road, it is remarkably similar. I can drive around but after about 4 seconds, it starts to miss and I basically need to floor it (full throttle should put it back in open loop right?) and it will muster itself out of the stall rev fully and run great. If I keep the throttle pegged, it is fine, however, can't zoom around northern colorado with my gas pedal at the floor all the time.
If back off of full throttle, after 4 seconds, the engine again, starts missing, then will stall after 3 more seconds if I don't floor it again to temporarily snap it into open loop.
I drove 60 miles home tonight and I got about 10 miles per gallon with all the revving every 5 seconds, so again, seems like it is running *way* rich? Also, I notice that even when I have it at full throttle, it will still miss every now and again and isn't really running perfectly smooth yet.
Some history...
My next thoughts and actual questions...
If anyone has any thoughts or suggestions, I would be very grateful. Im going to pull this baby into my garage tomorrow and fiddle with it every night until it runs the way it should. DOH!!
thanks
jess
Some history...
- In addition to the new engine rebuild, it has new 19lb injectors, new coil, new wires, new distributor and plugs. Timing @ 12 degrees.
- After the engine was rebuilt and installed it didn't really run well at all. The O2 sensor connector seemed to have melted at some point so this was deemed to be the problem and the O2 sensor replaced and the connector fixed. Seemed to be a little better, but not very good at idle still.
- Checked engine codes, nada. Seemed rich so we check the fuel pressure to see if it was wacky... seemed normal at 35psi.
- Thought the old 'Ignition Control Module' on the distributor might be the problem so we replaced it. No change.
- Got a random TPS range code, so we replaced that, seemed to make it run better at idle.
- Based upon posts here I checked the Idle Air Control (IAC), cleaned it out, linkage seems to be nice and smooth now. Didn't make any difference however.
- Thought maybe the 'Ignition Control Module' we got was bad, so we put in another one just in case... no change.
- The engine did this *before* it was rebuilt too, so there is something definitely lingering as a problem in the ignition system.
- I figure with the rich mixture the the 'new' O2 sensor might be fouled at this point? Do you think it might be worthwhile to try another one?
- My harness sucks, the connectors on the driver side fender are a mess, but I have checked all the connections and everything seems okay. I really should just buy new connectors and re-solder nice pins on each wire since I am an electronics person (computers not cars.
). Any suggestions on whether I should just get a new harness or try and 'fix' this old one?
- What else could be the problem? Im going to pull the ECM tomorrow and make sure the connector pins aren't oxidized etc. Beyond that, Im at the point of just going to a MAF system?
- I attached a photo of a mystery wire on my harness... it is coming from the driver's side firewall and has 12V on it when ignition is on so it must go somewhere since it isn't insulated. perhaps the insulator just fell off tho? The size of the female connector does not allow it to fit into any of the plastic connectors, so it doesn't belong in any of them as far as I can tell. It is Green with a Yellow stripe.
thanks
jess
