Rebuild or Replace? '02 Ranger 4.0
LLReb
So I have a 2002 4.0 and im 90% sure it has a cracked head. Coolant smells like exhaust and keeps blowing radiators. I used some head gasket sealer in the coolant and that seemed to work for a couple months but its time for a permanent fix. The truck has about 270k miles on it so I was looking for some input on whether to to buy a new head and try to rebuild it or look for a used motor with lower miles.
I am also planning on replacing the timing chain along with all the guides and tensioners if I decide to keep this motor. Also would like to know what else I should look into replacing while I have the motor out.
Any input or ideas will help! Thanks!
If I liked the truck, I would be cruising for a good used low mileage engine. Good hunting
A. What would it cost for ALL the parts to do your PARTIAL rebuild & how much time would it take (also oil pump & water pump)?
B. What would a good used engine cost & how long would the swap take?
Which choice do you like best LLReb?
From what I can tell they would cost about the same...($1000-$1500) A partial rebuild may even cost a little more. The only problem is finding a "good" used engine because you never know who owned it or what kind of maitenance was or wasn't done.
Time isnt really an issue as I have another vehicle in the meantime. A swap would be easiest and most likely cheapest. I am only afraid of running into the same issuses with a different engine. (cracked head, timing chain slap, etc...)
Thanks for the input! Giving me some things to kick around in the meanwhile.
A. What would it cost for ALL the parts to do your PARTIAL rebuild & how much time would it take?
Good points. After much thinking about this, I would prolly get sucked into doing this repair with a good used head, in my driveway at a snail's pace. :D
Granted ,its a OHC, but more head trouble again. WTF?
:icon_confused:
