Rebuild 3.0 flex.
Goldranger
Oregon
Had this truck for 8 yrs about .. bout 5 yrs ago it spun some bearings i replaced the crank..couple yrs ago developed cooling issues, cracked a head. Still had cooling issues. Traced it to corroded hose fittings on water pump and a cracked manifold hose fitting, not the big hose. So now i have 2 new heads new water pump & clutch fan. Its about to get a rebuild. Im so close to getting a c4 302 combo. Funny thing is a rented a car for work and they gave me a hemi powered warlock dodge 2020.
Waiting for a 31/2 ball hone ..its getting new crank rods pistons rings pushrods rocker arms...has new water pump clutch fan battery alt and starter.
did you get the cylinder top ridge removed???
new bearings will slam your new rings into that ridge.
The V8 sounds like a better option, lol
Electric fan would be good as well over a new fan clutch
