Rear windshield swap solid to sliding
Jay11
Texas
'99 4.0+'98 2.5
Will a 2003 Ranger sliding rear windshield fit a 98 2.5 regular cab with a single piece type windshield?
Target-1998 Ranger
Donor - 2003 Ranger
Rear slider is bolt in you will need some urathane to seal it.
I suspect that the solid window is bolt in as well
If I am correct you should be able to do the swap but I am not 100 % sure.
There were two types, bolt in and a regular type held in by the gasket. You can't swap between the 2 but if they are both bolt in they are compatible.
You can check if they are bolt in by just pulling back the panel below the glass and running your fingers along it. If you feel a bolt sticking out... well there you go.
